Hello everyone,,
I've been using the i3 pro b acrylic printer for about 7 months and found that meshmixer is a great tool, however I have to export files back to my computer and send them to slic3er to print as meshmixer does not recognise my printer.
Are there any settings that allow you to send directly from meshmixer to the pro b.snaptube.cam/ syncnet.onl/telegram-web/ 9apps
Using meshmixer on thei3 pro b
Re: Using meshmixer on thei3 pro b
Unrecognized this 3d model,
for all printing, you can only import its STL format into the slicing software and cut it into .gcode format.
then import it into the sd card or connect to the printer via USB for printing.
If it is printed for a long time, it is recommended to import it into the sd card for printing.
