Home problems with Pro C
Re: Home problems with Pro C
Hi, You can see if your wiring is correct on the motherboard,
If the motor is not running, you can try to exchange the motor shafts of other axes with the non-running motor wires to see if they are damaged.
If possible, you can provide your specific problem video so that we can better solve the problem.
