A10T profile
Sardauker
A10T profile
Post by Sardauker »
Hi all.
Is there, anywhere, a ready-made profile or a tutorial on how to build one?
I have so many newbie questions (purge, "in area" color mix, and so on), am I the only one? :D
Re: A10T profile
Hi, You can find the configuration of cura here: https://www.geeetech.com/download.html?download_id=47
If you need the configuration of Repetier Host, you can go here: https://www.geeetech.com/download.html?download_id=49
ControlsJedi
Re: A10T profile
Post by ControlsJedi »
Thanks for this info. I was able to use this with Cura 4.4.0. I just started my first print!
Geeetech A10T user
Marlin 1.1.8 with 3D Touch
Cura 4.4.0
Geeeko
Re: A10T profile
Post by Geeeko »
I received my A10T today and the Cura profile comes just in time, great ! :)
Request : please Geeetech, consider providing a plugin like 'colormix 2-1' plugin for Cura but using the 3 extruders (colormix handle only 2 extruders).
Question : Is there is a way to avoid that the heating head stay still for several seconds (waiting a temperature change even if there is no such change in the settings) over the printed object when switching to the next color/extruder ?
This creates 'blobs' of PLA that could ruin a print. Maybe there is a script possible that can move the head over the prime tower instead of waiting over the object ?
Jarda3d
Re: A10T profile
Post by Jarda3d »
If it is produced by Cura, look at specific custom gcodes if cura have it.
Else you can search in the text editor for M109 command in gcode file and delete it all except initialization (M109 S..... - temperature) and finish (M109 S0).
A10 Slic3r profile: here
Re: A10T profile
Geeeko wrote: Sun Dec 08, 2019 12:16 pm I received my A10T today and the Cura profile comes just in time, great ! :)
Hi, You can download the new version of color mix on the official website: https://www.geeetech.com/download.html?download_id=40
You can refer to this: viewtopic.php?f=92&t=69600
Geeeko
Re: A10T profile
Post by Geeeko »
M109, good to know, thanks for the hint.
Sardauker
Re: A10T profile
Post by Sardauker »
Thank you.
I just have to understand how to add a purge bucket in Repetier.
Again, thanks.
golfprinter
Re: A10T profile
Post by golfprinter »
William wrote: Fri Dec 06, 2019 9:30 am Hi, You can find the configuration of cura here: https://www.geeetech.com/download.html?download_id=47
I downloaded the Repetier-Host file but I don't know what to do with it. It came with two files. Do I have to drop them in a certain folder? I tried to find a way to import them but I didn't see that.
Thank You!
Re: A10T profile
golfprinter wrote: Thu Dec 12, 2019 10:16 pm
Thank You!
Hi,I will explain to you through the picture.
I hope this can help you.
