No 3d Touch in the menu
Gr1f1S
Post by Gr1f1S »
Hello ,
I'm a very noob in 3d printing.
Today I assemble my geeetech A20 and I'v installed the3d touch .
Firmware is Marlin 1.1.8 but i did not see a 3d touch menu on the lcd i see the auto home option but not the 3d touch menu.
Can please help me ? i refer the video to mount the 3d touch on the board i put the 3 pin first ( brown cable first ) and then the two pin ( black cable first ).
Gr1f1S
Re: No 3d Touch in the menu
Post by Gr1f1S »
Thanks for the quick reply, wich firmware i have ti install marlin 2.0 ? Or i have to change the current firmware? Thanks again
Gr1f1S
Post by Gr1f1S »
Ok I have another problem , i download Marlin firmware 1.1.9 with 3d touch enabled compiled with arduino 1.8.5 , the sketch compile fine then i run upload , after upload complete I've restarted the printer but the lcd is blank nothing appear.
Retried but nothing.
Any suggestion ?
Gr1f1S
Post by Gr1f1S »
Other update , i've downloaded the firmware from here :
https://www.geeetech.com/forum/download ... hp?id=5405
but arduino wont compile.... this is the error :
Arduino:1.8.5 (Windows 10), Scheda:"Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\SCOVAREL\Documents\Arduino\libraries -fqbn=arduino:avr:mega:cpu=atmega2560 -ide-version=10805 -build-path C:\Users\SCOVAREL\AppData\Local\Temp\arduino_build_435861 -warnings=none -build-cache C:\Users\SCOVAREL\AppData\Local\Temp\arduino_cache_321434 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\SCOVAREL\Desktop\Stampante 3d\firmwarenuovo\A20_Marlin-1.1.x12864_3DTouch\Marlin\Marlin.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\SCOVAREL\Documents\Arduino\libraries -fqbn=arduino:avr:mega:cpu=atmega2560 -ide-version=10805 -build-path C:\Users\SCOVAREL\AppData\Local\Temp\arduino_build_435861 -warnings=none -build-cache C:\Users\SCOVAREL\AppData\Local\Temp\arduino_cache_321434 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\SCOVAREL\Desktop\Stampante 3d\firmwarenuovo\A20_Marlin-1.1.x12864_3DTouch\Marlin\Marlin.ino
Using board 'mega' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "C:\Users\SCOVAREL\AppData\Local\Temp\arduino_build_435861\sketch\Marlin.ino.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "C:\Users\SCOVAREL\AppData\Local\Temp\arduino_build_435861\sketch\Marlin.ino.cpp" -o "C:\Users\SCOVAREL\AppData\Local\Temp\arduino_build_435861\preproc\ctags_target_for_gcc_minus_e.cpp"
C:\Users\SCOVAREL\Desktop\Stampante 3d\firmwarenuovo\A20_Marlin-1.1.x12864_3DTouch\Marlin\Marlin.ino:45:110: fatal error: U8glib.h: No such file or directory
#include <U8glib.h> // library for graphics LCD by Oli Kraus (https://github.com/olikraus/U8glib_Arduino)
compilation terminated.
exit status 1
Errore durante la compilazione per la scheda Arduino/Genuino Mega or Mega 2560.
My lcd is still blank Any idea ^?
Gr1f1S
Post by Gr1f1S »
Thanks Vert ,
I make a try when come back to home from work.
Regards.
Gr1f1S
Post by Gr1f1S »
Update , everyting work now thanks for support
