AutoHome issue
AutoHome issue
Am facing an issue with my MeCreator2 printer.
While hitting the Auto Home from the control panel, it's starting to move to home position but for X and Y-axis it makes a strange noise, trying to move more than the MIN position !
Actually, it does not stop even if it reaches the endstop and strange noise appears for some seconds, only for X and Y, not facing it for the Z-axis.
I've checked the endstops and they are correctly connected and well functioning!
I tried using the 'Set Home Offsets' and 'Store memory' after moving the head at the home position but still facing same when hitting AutoHome from control panel...
I assume it could be fixed in the configuration.h file but I would need some assistance to do it properly.
Re: AutoHome issue
Hi, You can try to connect your printer to Repetier Host and enter M119 in the manual control to check the limit switch.
You can refer to: http://geeetech.com/forum/viewtopic.php?f=17&t=60927
Re: AutoHome issue
Thanks for your replies guys.
M119 shown me that endstops are working well when nozzle is at the center.
However, what I saw for X-axis endstop is very strange.
The endstop red light is off when X-axis is at position 0. And it switches on only if I move it from some centimeters (around 10 approximately)
On what is it based ? Does light switch on software event or hardware one ?
For Z and Y-axis, red lights are on when nozzle is at home position. (BTW, by doing a home position for Z or Y, there is no strange noise)
This 'offset' on X-axis seems the key of my issue I think.
Re: AutoHome issue
Progressing myself on the resolution of the issue by scrutinizing my printer carefully.
When I can get the endstop red light on, everything works well, but for that I need to push firmly on involved cable connector.
So seems that X-axis endstop wire is causing the issue, reacting differently when I'm pressing the cable conductor...
Will keep you posted guys
ElviraNance
Re: AutoHome issue
Thanks for sharing, I'll happily use it if I have such an opportunity earlier.
Ignacioebster
Re: AutoHome issue
Mostly peoples have to face Autohome issues when they gone for picnic or trip. If you don't want to face these kind of issue so click on bulk url opener and read some useful tricks before going a long trip.
Re: AutoHome issue
bigcommerce quickbooks integration
It will save your time and money by integrate your sales data with QuickBooks. BigCommerce offers a simple solution to start an online store. It will save your time and effort on data entry and it will automate your BigCommerce orders with inventory, shipping and accounting.
Re: AutoHome issue
Mind blowing post you have shared for us. I specially congratulate you for this kind of post. Satta Matka
Re: AutoHome issue
May be undervalued. Its Value Score of B indicates it would be a good pick for value investors. The financial health and growth prospects of ATHM, demonstrate its potential to outperform the market. It currently has a Growth Score of D.
https://www.skylightpaycard.online/
