A10M 2 filament not mixing well!!!
miguelpikons1
Post by miguelpikons1 »
Hi all,
I'm new to the forum. I tried to dig a bit but i couldn't find an answer yet.
I've very recently entered in the world of 3D printing and bought the Geeetech A10M as the dual extruder kind of pumped me up (to the point that i almost regret not to have bought the A20T).
Regardless.. I quite like the printer but i'm facing an issue and i'm not sure if i have a real problem or my inexperience is playing the main role:
I'm trying to print with a color mix (in my case specifically i have red in one extruder and blue in the second attempting to have a grade of purple).
However the mixing is uneven... very uneven. The resulting model is a vertical split between the two colors.
The left side ends up being almost purple while the right side is light blue with no real expected mixture outcome
Is there anything i can do to fix this and have a full mix of the colors?
Re: A10M 2 filament not mixing well!!!
:D Hi,You can try downloading the color mixing software on the official website to set the color mixing.
Download link: https://www.geeetech.com/download.html?download_id=40
You can refer to: viewtopic.php?f=92&t=61760
Jarda3d
Post by Jarda3d »
It is possible to fix it with new hotend nozzle.
Get beneral MK10 nozzle from e-bay. look at the 4mm cave here... If cave will be filled with some thing like turbine for mixing "toothpaste", you will get nice mixed colour in output.
I did not try plain cave, because all what I was get is steel one and not brass as ordered.
A10 Slic3r profile: here
