Lines in prints
evant8950
Lines in prints
Post by evant8950 »
Hey everyone,
Does any one have any suggestions on how i could fix the lines appearing in my prints?
Below is my slic3r profile. I would greatly appreciate any suggestions. Thanks!
# generated by Slic3r 1.3.0 on
adaptive_slicing = 0
adaptive_slicing_quality = 75%
avoid_crossing_perimeters = 0
bed_shape = 0x0,230x0,230x230,0x230
bed_temperature = 55
before_layer_gcode = M117 Printing layer [layer_num]
between_objects_gcode =
bottom_infill_pattern = rectilinear
bottom_solid_layers = 3
bridge_acceleration = 0
bridge_fan_speed = 100
bridge_flow_ratio = 0.95
bridge_speed = 30
brim_connections_width = 0
brim_width = 0
compatible_printers =
complete_objects = 0
cooling = 1
default_acceleration = 0
disable_fan_first_layers = 2
dont_support_bridges = 1
duplicate_distance = 6
end_filament_gcode = "; Filament-specific end gcode \n;END gcode for filament"
end_gcode = M117 Finished printing. ;Put printing message on LCD screen\n\nM104 S0 ;extruder heater off\nM140 S0 ;heated bed heater off (if you have it)\n\nG91 ;relative positioning\nG1 E-1 F300 ;retract the filament a bit before lifting the nozzle to release some of the pressure\nG1 Z+0.5 E-5 X-20 Y-20 F9000 ;move Z up a bit and retract filament even more\n;G1 Z+0.5 E-5 X-20 Y-20 F9000 ;move Z up a bit and retract filament even more\nG28 X ;move X to min endstops so the head is out of the way\nG1 X0 Y200 F5000 ;\nM84 ;steppers off\nG90 ;absolute positioning\n
external_perimeter_extrusion_width = 0
external_perimeter_speed = 20%
external_perimeters_first = 0
extra_perimeters = 1
extruder_clearance_height = 20
extruder_clearance_radius = 20
extruder_offset = 0x0
extrusion_axis = E
extrusion_multiplier = 1
extrusion_width = 0
fan_always_on = 1
fan_below_layer_time = 20
filament_colour = #B082FF
filament_cost = 22
filament_density = 1.25
filament_diameter = 1.75
filament_max_volumetric_speed = 0
filament_notes = ""
filament_settings_id = ""
fill_angle = 45
fill_density = 20%
fill_gaps = 1
first_layer_acceleration = 0
first_layer_bed_temperature = 55
first_layer_extrusion_width = 120%
first_layer_height = 0.3
first_layer_speed = 20%
first_layer_temperature = 190
gap_fill_speed = 20
gcode_arcs = 0
gcode_comments = 0
gcode_flavor = reprap
has_heatbed = 1
host_type = octoprint
infill_acceleration = 0
infill_every_layers = 1
infill_extruder = 1
infill_extrusion_width = 0
infill_first = 0
infill_only_where_needed = 0
infill_overlap = 25%
infill_speed = 60
interface_shells = 0
interior_brim_width = 0
layer_gcode =
layer_height = 0.2
match_horizontal_surfaces = 0
max_fan_speed = 100
max_layer_height = 0.25
max_print_speed = 60
min_fan_speed = 100
min_layer_height = 0.07
min_print_speed = 10
min_skirt_length = 0.4
notes =
nozzle_diameter = 0.4
octoprint_apikey =
only_retract_when_crossing_perimeters = 1
ooze_prevention = 0
output_filename_format = [input_filename_base].gcode
overhangs = 1
perimeter_acceleration = 0
perimeter_extruder = 1
perimeter_speed = 40
perimeters = 3
post_process =
pressure_advance = 0
print_host =
print_settings_id =
printer_notes =
printer_settings_id =
raft_layers = 0
regions_overlap = 0
resolution = 0
retract_before_travel = 2
retract_layer_change = 1
retract_length = 6
retract_length_toolchange = 10
retract_lift = 0
retract_lift_above = 0
retract_lift_below = 0
retract_restart_extra = 0
retract_restart_extra_toolchange = 0
retract_speed = 40
seam_position = random
sequential_print_priority = 0
serial_port =
serial_speed = 250000
shortcuts = support_material
skirt_distance = 0
skirt_height = 1
skirts = 0
slowdown_below_layer_time = 5
small_perimeter_speed = 20%
solid_infill_below_area = 5
solid_infill_every_layers = 0
solid_infill_extruder = 1
solid_infill_extrusion_width = 0
solid_infill_speed = 60
spiral_vase = 0
standby_temperature_delta = -5
start_filament_gcode = "; Filament gcode"
start_gcode = M117 Preheating... \nM104 S[first_layer_temperature] ; pre heat nozzle to ...\nM140 S[first_layer_bed_temperature] ; warming the bed to ...\n;----------------------------------------\nM117 Homing;\nG28; Home all 3 axis\n;----------------------------------------\nM117 Auto leveling;\n;M420 S1\nG29 V3; run auto level\n;----------------------------------------\nM117 Nozzle\nG1 Z0.5 F300\nG1 X210 Y210 F3000\nG1 Z0 F300;\n;----------------------------------------\nM117 Continuing Heating\nM190 S[first_layer_bed_temperature]\nM109 S[first_layer_temperature] \n;----------------------------------------\nM117 Priming\nG92 E0 \nG1 F300 E-0.5\nG0 X210 Y10 Z0.2 F5000\nG1 F400 E8\nG1 X10 E25 F800\n;G4 P500 \n;----------------------------------------\nM117 Printing...\nM900 K0.75
support_material = 0
support_material_angle = 0
support_material_buildplate_only = 0
support_material_contact_distance = 0.2
support_material_enforce_layers = 0
support_material_extruder = 1
support_material_extrusion_width = 0.36
support_material_interface_extruder = 1
support_material_interface_extrusion_width = 0
support_material_interface_layers = 1
support_material_interface_spacing = 0.25
support_material_interface_speed = 80%
support_material_max_layers = 0
support_material_pattern = rectilinear
support_material_spacing = 2
support_material_speed = 30
support_material_threshold = 10
temperature = 190
thin_walls = 0
threads = 8
toolchange_gcode =
top_infill_extrusion_width = 0
top_infill_pattern = rectilinear
top_solid_infill_speed = 60
top_solid_layers = 3
travel_speed = 120
use_firmware_retraction = 0
use_relative_e_distances = 0
use_set_and_wait_bed = 0
use_set_and_wait_extruder = 0
use_volumetric_e = 0
vibration_limit = 0
wipe = 0
xy_size_compensation = 0
z_offset = 0
z_steps_per_mm = 0
Re: Lines in prints
:D Hi, You can try to turn off the z-hop, and then check your mechanism for loose parts,
Tighten it if it is loose.
