trying to load new firmware A30
Infidel
Post by Infidel »
I am trying to update the a30 firmware. I downloaded the latest firmware file from Geeetech. I have my laptop connected to the printer and printer shows up as com3 in the device manager. When I run main, I see Com 3 at the top. I do not see the two buttons that are supposed to be at the bottom of the program (version 2.0). So when I select the mainboard bin file it gives me a green check but I can not do anything.
Any help appreciated.
Re: trying to load new firmware A30
:D Hi, if so,
You can install the driver manually,
Specific operations refer to this: https://www.geeetech.com/forum/viewtopi ... RlcFtWdCG4
Then select the corresponding port,
Then upload the firmware.
viewtopic.php?f=20&t=68694
Infidel
Post by Infidel »
I installed the latest USB driver for the printer. My printer has the CH340 chip. Does this look right (see screenshot of my device manager below)?
I am still unable to install firmware. The main.exe opens, but it does not have the controls across the bottom. I can select the BIN file but that is all that is happening. Attached is a screenshot of the main.exe without any controls. Without the controls I cannot install the firmware. Is there something wrong with my Printer?
This is the Main.exe running.
Smatto screen grab.jpg (119.59 KiB) Viewed 5381 times
this is the device manager display for the com port.
Infidel
Post by Infidel »
Should I try the FT USB driver?
Infidel
Post by Infidel »
Yes i tried but didn't have a hex file for the A30. do you have one? I am willing to give it a try.
