Just getting started
Flash Brasbo
Post by Flash Brasbo »
I've set up and leveled the printer, but it doesn't print, it moves around the pattern, but no filament is on the table.
Re: Just getting started
:D Hi,you can try to heat the temperature to around 200,
Then manually push the supplies,
Determine if the material can be discharged normally,
If it is blocked, you need to use a cleaning tool.
to clean it up.
