Working triple Color Mixer for Cura 4.4.1 (NodeJS)
Possum
Post by Possum »
Being disappointed with the issues of standard Geeetech color mixer software that fails to work with the Cura gcode (mode with three extruders), I wrote simple color mixer for NodeJS. I have tested it on my A20T and found no errors. Sources in attachment.
possum_mixer.rar
sources of color mixer (NodeJS should be installed)
(1.61 KiB) Downloaded 842 times
cjmdh77
Re: Working triple Color Mixer for Cura 4.4.1 (NodeJS)
Post by cjmdh77 »
Never mind figured it out.
cjmdh77
Post by cjmdh77 »
Cannot get it to work. Either it errors out at 99.5% on 216 layer gcode or returns nothing at all.
layer: 215 progress 99.5%
(node:20448) UnhandledPromiseRejectionWarning: TypeError: Cannot read property 'indexOf' of undefined
at mixColorForRange (C:\Users\cjmdh\Desktop\3D Projects\mixer\mixer.js:63:17)
at start (C:\Users\cjmdh\Desktop\3D Projects\mixer\mixer.js:13:4)
(node:20448) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 1)
(node:20448) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
Possum
Post by Possum »
You have to properly set config.json according to layers amount of your model and your color-mix scheme. Do not use my config.json.
cjmdh77
Post by cjmdh77 »
Yes, made my own config. Layers were 216, used my own mix but still received the error.
KriKri854
Post by KriKri854 »
How do I use/install this possum mixer
xg12
Post by xg12 »
KriKri854 wrote: Wed Sep 23, 2020 10:02 pm How do I use/install this possum mixer
Hi, can somebody help us?
