LCD display turns only green
Jassim
Post by Jassim »
I bought 4 days before Acryl Prusa I3 Pro B. Machine prints well with Repetier-Host and USB, but I have a problem. The LCD display turns green and don't have any symbols on it. I checked the cables for the SD card and the display, it OK. Also when I press the main switch board beep.https://speedtest.vet/ https://vidmate.bid/ https://123-movies.red/
I will ask for help!
Re: LCD display turns only green
:D Hi, You can plug and unplug the screen,
This may be caused by poor wiring or signal interference.
Reese89
Post by Reese89 »
The problem with the display being green is caused by a bad connection between the monitor and the video card (specifically the data cable). This cable is what sends the information from the video card to the monitor. If it does not have a good connection, then the monitor will not receive the information correctly and show a distorted image or no image at all. However, I have to solve it. Meanwhile, Best Assignment Services is handling my academic burden. It feels so good to hire the service of professional individuals.
