Firmware with working 3D touch?
TehZuCC
Post by TehZuCC »
Has anyone gotten 3d touch to work correctly? Just upgraded firmware to V1.01.01 and the auto leveling screen still does not allow me to select 3D touch, still stuck on "CAS". Also no buttons for push-pin up/down or alarm release.
Edit: Turns out you have to turn auto leveling off before selecting 3d touch.
Maccron
Re: Firmware with working 3D touch?
Post by Maccron »
A30M with 3DTouch.
liberator
Post by liberator »
Yes, I too finally figured out from the poor wording in the manual that you have to turn off the auto-level switch icon to go to 3d touch from the CAS default.
Then once you select the 3d touch sensor, you switch the auto-level back on.
It tests fine on the up down and alarm. Also, when you hit the measure icon, it goes to the center position where you can set the offset, so the sensor is working.
How do you get it to "auto level" and go to all 9 other positions??? We need the auto level, since the plate is warped enough so that manual level does not allow a uniform thickness first layer to be put down.
PLEASE HELP ASAP. THANKS
Maccron
Post by Maccron »
A30M with 3DTouch.
