Astroprint settings
luckycreature
Astroprint settings
Post by luckycreature »
Hi. My wife got me one of these for Christmas used second hand. Only problem is it doesn't have wifi so I cant use web apps and I use a chromebook.
I have figured out how to get Astroprint to save to an a sd card but I cant find out the right settings for astroprint to work.
Does anyone mind sharing the correct things to put into astroprints web browser settings for the 180 to work correctly?
Thanks!
3dprintingiscool
Re: Astroprint settings
Post by 3dprintingiscool »
For the build size you should use 130*130*130 as build size, no heated bed, nozzel dimentions .4, print speed 80-100mm/s, fdm as the type of printer, filment diameter 1.75, and one extruder/hotend im 12 ive been usining 3d printers for about 2 years now so if you have more questions just ask :).
ElviraNance
Post by ElviraNance »
Did you use it for your personal purposes only or for the work also? I'll gladly try, but I didn't find so many types. That is why I happily started to work with https://anisoprint.com/ as the most interesting variant of 3d printers for me.
