adjusted driver voltage from .8 to 1 now x axis dosnt move and x driver gets very hot
Bluesandbox
Post by Bluesandbox »
I adjusted the voltage for all the drivers from.8 to 1 because the motors could barely push filament (i could easily push manually), now the x-axis doesn't move and the driver for it gets very hot and reads 0.5 volts. I switched the wire to the y-axis and it won't move either, so it isnt the wire or the motor is self
Re: adjusted driver voltage from .8 to 1 now x axis dosnt move and x driver gets very hot
Hi,if you swap the position of the motor slot on the motherboard, and then the motor does not run properly, there may be a problem with the motor slot on the motherboard. Is your x-axis corresponding motor inserted into the drive board?
