Trying to test GT2560 V4.0 board
luqasonce
Post by luqasonce »
Hi!
I have an A10M printer and yesterday the board suddenly died. I have been cleaning the hotend and after the assembly, when I turned on the printer the display started for a second and turned off.
Checking the board I have found a blown fuse (the 10A one), so I want to test if the board is still alive before buying the new fuse.
How can I test the mainboard? Any way to power it via usb to test if the atmega responds?
Any help is appreciated!
Re: Trying to test GT2560 V4.0 board
Hi, you can connect the printer to the slicing software via USB,
See if you can control the printer.
luqasonce
Post by luqasonce »
Thanks for the answer William!
No, mi computer isn't detecting the printer.
I guess the microcontroller is powered via the 24v power source, and without the fuse no current reaches it.
No leds are turning on in the board at any moment.
Edit: I have tried to connect the good fuse replacing the blown one. Y kept everything disconnected except the display. When powering on the printer, the display and the board are working fine. So I will get the replacement for the fuse.
Now I am questioning why this fuse has blown. I have made a shortcircuit in the resistor or the fans in the hotend? Or maybe is something else what im not seeing?
Hi,may be caused by poor contact.
luqasonce
Post by luqasonce »
Hi.
I have checked all the cables and connections at the hotend and everything looks good, it's really strange.
I will test the connections to see if everything is ok before powering the printer and I will post the results.
