Firmware arduino error
realmrcool
Post by realmrcool »
Hello I just tried to upload my new firmware.
when i hit verify this error massage shows:
error: using typedef-name 'fpos_t' after 'struct'
I*m using a geeetech prusa i3 pro w
using the I3 ProW GT2560A+ with 3dtouch.zip firmware
any idea whats wrong?
Re: Firmware arduino error
Hi, you can try,
Upload using Arduino 1.0.1 or
changing all instances of "fpos_t" to "fpost"
realmrcool
Thanks that worked.
Any idea why my bltouch is flashing after self test?
I think it's faulty, after a few selftesting instanced it stopped showing any light and doing no selftests.
Also when trying to level it did not use its prob just slaming the z axis...
Hi,Can you provide specific videos?
realmrcool
Like i said. Now it stopped working all together. No light no movement nothing.
Before that. It did the selftest (2 probe klicks and then flashing) but when it was on x0 y0 z0and did only touch the edge of the heat bed without the glas it seamed to work. Maybe the offset was wrong. But now it stopped working all together. No light no probe klick no nothing.
I can make a video but nothing to see
realmrcool
https://youtu.be/gjh2F6DJB0k
The wiring is exactly as shown in the tutoral on your Homepage
Hi, Send the commend "M280 P0 S160" to release the alarm in Repetier Host.
Rotate the screw on the top of 3D Touch with a screwdriver to lift up the NEEDLE,
cuz the NEEDLE may drop down a little somehow.
If it doesn't work,
3d touch itself has problems,
You can try flashing the firmware back to the version without 3d touch
Check to see if the printer works
realmrcool
Without the touch Sensor it all works as intended.
I really guess the sensor is an ex sensor.
I will get an replacement and keep testing.
Once again thanks for all your Support william.
You kept me going at the start of this exciting hobby.
I will share my results as soon as i finished my upgrades/ calibrations
By now i really got some nice miniatures printed with the i3 pro w :)
realmrcool
Hello william.
I orderd the replacement for the sensor.
I still got the red light flashing if the nozzle is near the hot bed. I guess my offset is wrong.
(If i try the autohome my nozzle goes way to deep till the z axis jams.)
I used the Firmware preconfigured for the i3 pro w with touch sensor, at the Firmware download.
And the mount from the Installation guide.
After it did not work i changed All the values of the preconfigured Firmware to the values of the Installation guide.
Still same results. here some example of the error (i did not show the autohoming since crashing the nozzle is not fun to demonstrate ;)
https://youtu.be/rvQDlbbiyGg
Any idea what im doing wrong?
