Some time ago i got a geetech prusa i3 pro w, and recently ir has been giving me some problems. It will print perfectly for a while, then suddenly stop printing and enter in a cycle of aproximately 4 seconds, in which:
-the lcd screen will turn on and off
- the y axis motor makes 2 clanking sounds, in between of which it blocks itself
-an orange led blinks twice in the motherboard, which is the model gt2560 rev A+, specifically the led in the middle above an L.
Please help, becouse this problem has ruined several prints and tends to happen quite late, though it seems to happen at any time.
Thank you for your time
Problem with prusa i3 prow
Re: Problem with prusa i3 prow
Hi, Is there a pause command in your print file,
You can change the model and re-slice for printing.
It is not a problem with the file, becouse i hace tried different files, different programs and even different computers
Hi, do you print via USB or sd card?Rubengg wrote: Thu Mar 26, 2020 9:31 pm It is not a problem with the file, becouse i hace tried different files, different programs and even different computers
You can try to update the firmware, use the official website firmware,
Upload with firmware toolkit,
Then print it,
If the pause persists,
There may be a problem with the motherboard chip.
I print via USB, I`ll check later the firmware
