Please tell me how i can set everything to factory defaults, i think i used an unknown g code and changed the quality false so that the z axis dont work right now. Plesse tell me the parameters of the factory defaults variables or tell me how i can define them in the firmware
Thx
Factory default
Re: Factory default
Hi, You can perform recovery operation through the screen
Or update the firmware again.
Re: Factory default
ok thats what i have done , a firmware flash but the problem with my z axis is still there
Re: Factory default
Hi, Is the z-axis motor not working properly?novawaves wrote: Mon Mar 30, 2020 10:21 pm ok thats what i have done , a firmware flash but the problem with my z axis is still there
You can exchange the other motor end wires with the z-axis motor wires.
Check if the motor cable is damaged.
