Z Axis Issues
EpicDr1zzt
Z Axis Issues
Post by EpicDr1zzt »
So i purchased the I3 Pro W as my first printer, probably should have gotten a prebuilt because im having a lot of issues. My Z axis is not working properly, i have leveled it and done everything i can to fix it on my own. I have put in the proper Z codes i believe however the right motor is rotating faster than the left rod and the left rod will catch and not move at all. I have checked the rods for imperfections, i have checked to make sure the rods can move properly, i have tried changing the stepper drivers, ive tried re-uploading the firmware, i dont know what else i can do. Any help would be amazing!
Re: Z Axis Issues
Hi, You can remove the z-axis threaded rod to see if the left and right motors are running synchronously.
After the z-axis is installed, the left and right z-axes need to be on the same horizontal line.
EpicDr1zzt
Re: Z Axis Issues
Yes they run synchonously without the rods and the stopping seems to be done. but ive already swapped the rods and the holds for them. I dont know what it could be, i thought that it was the x axis belt being to tight and pulling them inward but it does it with the belt off too. ive checked the rods for imperfections that could cause it to catch. do i just not have enough voltage to the motors? How would i fix that? i dont have something to check the voltage unfortunately
Re: Z Axis Issues
Hi, You need to properly mount the z-axis threaded rod through the coupling,
And check if the left and right z-axis are on the same horizontal line.
EpicDr1zzt
Re: Z Axis Issues
I checked to make sure they werent cross threaded. The z axis goes down just fine. just not up
EpicDr1zzt
Re: Z Axis Issues
I just checked to make sure they were on the same horizontal axis. They are now, same issue. Goes down, but not up
Re: Z Axis Issues
Hi, Can you provide specific question videos?
EpicDr1zzt
Re: Z Axis Issues
It wont let me due to it being an MP4 however here is the link sharing link https://s.amsu.ng/TSgUOH7VuTPN
EpicDr1zzt
Re: Z Axis Issues
Here is the youtube link https://youtu.be/cJwVfxburag
enflo
Re: Z Axis Issues
Post by enflo »
I have the same problem
It happens to me when the z-axis is in the initial position, which is unable to climb, it gets stuck.
