Another setback - Now the bed heater has quit.
Hopsing
Post by Hopsing »
Just when I thought I was finally going to get to use the printer the heated bed has failed. When will this madness stop. I need to know the voltages that I should see on the pins when the heat should be heating up. Also, does anyone have the resistance values you should see on these points? I have attached a picture of the points I am interested in. Thank you collectively for your support. Hopsing
Re: Another setback - Now the bed heater has quit.
Hi, You can measure the resistance of the blue-green line.
Hopsing
Post by Hopsing »
Does anyone know what resistances you should view on this connector?
Hopsing
Post by Hopsing »
I only can read 5.0 volts to the pins on this connector. What should be the voltage to these pins?
