A10m Extruder blocked
BeanCounter
Post by BeanCounter »
My A10M has had an ABS filament snap off just below level of extrusion head - and upon further inspection it looks like there may be a second filament piece jammed in well down. Tried heating to 240 and pushing through - doesn't help. Any ideas on how to get filament out appreciated - photo of issue attached
Re: A10m Extruder blocked
Hi, You can try heating the temperature to 250,
Use the cleaning tool to see if you can eject supplies.
If it cannot be pushed out, the hot end needs to be replaced.
ArmandBaker
Post by ArmandBaker »
Assuming you need to partake in the best Buffet near me on the planet Las Vegas is the spot to be. Here you can discover some of all that everything you can eat café which likewise give 24 hour passes to permit you to enjoy all the food you might conceivably appreciate.
