extruder motor i think.
organic
Post by organic »
M201
I’ve had this printer a while now and not been able to print anything so I got it back out because of off our lockdown to try again.
I have replaced the heat bed and the control board and a few other bits.
The extruder motor now turns then jumps back about an 1/8 rotation that’s both motors doing it.
I now you can change voltage on the stepper but will work? As I am not willing to spend loads of money on it as I have had it a long time and will put money to another one.
I would like to know do I have to set stepper motor with new control board and to what voltage.
1 is 0.56 and the other is 0.62 volts
Thanks for any help in advance.
Organic
Re: extruder motor i think.
Hi, the voltage is around 0.8V-1.2V like the picture.
organic
Post by organic »
I move them both to 1.0 volt then to 1.14 and the other to 1.16 volts that seem to be max they go up to but still same. I do have a two videos of what is going on but not let me atach them .mp4.
Thanks for help.
https://drive.google.com/open?id=1rzsAL ... 9AFv9LP5uQ
Hi,You can swap the driver to see if it is normal.
you can refer to this :viewtopic.php?f=17&t=17038.
Hope to help you.
organic
Post by organic »
I have swopped the stepper motors around and cable still same is that what you mean by driver?
My board is the GTM32 B and in one of the pictures A4988 all jumpers in and the other on only 1 jumper is in. On my board all 3 jumpers in on all of them.
It all said on the GTM32 is 3.3V mine is 3.25 on both the extruders motors.
Did I say the same thing is ongoing in the other extruder motor when I change the mix.
I all so noticed just before printer starts the print and does the purge filament the extruder turn ok well I think so does about ½ turn with out jumping back.
Organic
Hi,each driver must be plugged with three jumper caps.
organic
Post by organic »
I dont know what ive done seems to be working now I flashed firmware unpluged control board and put back in recliced program and seems to be working whell the extruder motors any.
Is ther any where I can find basic print help for that modal M201 and how to use the Easy Print 3D.
I keep getting and dont know what it means.
The argaments had been set but not used in slicing
Dave
Hi, it is recommended that you use Repetier—Host.
you can refer to this:
Geeetech Prusa I3 M201 使用手册英文 .rar
(2.93 MiB) Downloaded 553 times
organic
Post by organic »
That link I not seem able to get it to work/open.
(windows 10)
Organic
Got it to open thanks.
organic
This is the user manual, you can use Repetier-Host.
Now Easy Print 3D is rarely used.
