Filament Loading
lmendpin
Filament Loading
Post by lmendpin »
Hello, I am in the process to setup an i3 x 3D printer. I alredy calibrate position on all axis. But now I want to load filament in order to do a test. But my surprise isn´t loading filament option in the menu printer. So How do I load the filament???. Please help. Before that I use this link in order to donwload marlin firmware because one axis went in reverse way. I do not know if the firmware I download is the problem.
I download the firmware from this topic.
viewtopic.php?f=10&t=17046
Please help me.
Regards
Luis .
Re: Filament Loading
Hi, you can refer to this:viewtopic.php?f=17&t=17037
Hope to help you.
lmendpin
Post by lmendpin »
Thank you. I fix it with the 3D wifi. The app has an option. Also I can push it manually.
