paramètres d'origine
cchristel83
bonjour. j'aimerais avoir un lien pour remettre les paramètres d'origine. les moteurs Z tournent plus vite qu'avant un téléversement sur Arduino et du coup mes impressions sont des pièces montées. alors qu'avant la seule impression que nous avons pû faire était parfaite. merci de vos réponses
Re: paramètres d'origine
Hi,do you mean you need to download the firmware again?
cchristel83
Hi . Unfortunately, I listened a bad device and I did a sweep with Arduino. Since, Z engines are turning a lot more and the impressions are ugly and not structures. So I would like to find my old version, thé original version. thanks
Hi, please excuse my French is not very good, I guess you may need this:
you need to upload the firmware via Arduino IDE 1.0.1.
If you upload the FW via Arduino 1.8.5 then you will get the error:
fops_t or X/Y/Z min pin redefine:
cchristel83
the engines on the Z axis are turning too fast. I manually modified 2560 around 400 because I have threaded rods but the printer does not keep this parameter in memory. I am not good at programming, so I am looking for a simple solution, thank you
Hi,you can save the parameter settings by motor store setting.
