i've got an old 16Mb Sd Card... is unused so i'd like to use it to pass gcode files from PC to A20.
Unfortunally the A20's card reader doesn't recognize this SD CARD.
Do you know if there is a way (maybe with some particular formatting trick) to make that SD card readble from the printer?
Thanks a lot.
Using old 16Mb SD card... is it possible?
Re: Using old 16Mb SD card... is it possible?
Hi,it is recommended that you replace the SD card.
Ok, thanks a lot.
