A30 Extruder Caliberation
Post by 156801 »
can someone please explain how to extrude 100 mm of filament so I can calibrate the extruder?
I can not see anything on the touch screen to do it.
Robert
Re: A30 Extruder Caliberation
Hi,you can set the nozzle temperature to the target temperature (190 ~ 210 ℃) when printing PLA consumables. After the temperature is stable, operate the extruder feed on the touch screen.
as the picture shows.
The extruder will automatically feed until the nozzle has molten filament extruded. Select E0, E1, E2 extruder feed in sequence.
156801
Post by 156801 »
Hi Willian,
Thanks for the reply.
I tried what you suggested but it just kept extruding it did not stop at 100 mm. The touch screen display looks different.
Firmware is V1.35.56
Robert
Hi,stop heating consumables will not melt again, if there is still a part of the outflow is normal, it has been heated and melted in the hot end. You can try printing to see the effect.
