A30T BUG LIST
gio@dkonline.be
A30T BUG LIST
Post by gio@dkonline.be »
3D touch dont work, dont give 2X same value (tested with3 different 3D touch), Proxy sensor Work
Fan for fanduct too weak.
printer make many many many noise, need TMC drivers and replace 8010 fan case by a silent system.
Mix menu is not translated.
after reset software, all axis inverted and pid value replaced by bad value, need firmware update urgent.
need a good profil for cura, and other, too many stringing with mix extruder....
printer has good potential but still needs a lot of adjustment.
Re: A30T BUG LIST
Thanks for your feedback, we will improve as soon as possible.
gio@dkonline.be
Re: A30T BUG LIST
NO PROBLEM
i have found a hardware problem on mainboard....
check with conceptor to reinforce line of fanduct fan, the thyristor dead by itself, same for other user of A30T.
after component replaced, fan ok
ans Y motor is to low, need to replace by a bigger,he loose step at 60mm/sec, i do try with a close loop this week
