Auto bed leveling on A30 connection.
Posted: Mon May 25, 2020 10:10 am
by alexy34
Hi everyone,
I want to install a 3DTouch auto bed leveling sensor on my A30.
Did these pins on the back of extruder are for connection ? P.S. see picture.
Anyone has a picture how these plugs are connected ?
Do i need a firmware update ? or just connect the auto leveling sensor and do the setup on the lcd screen ?
Re: Auto bed leveling on A30 connection.
Posted: Mon May 25, 2020 10:35 am
Hi,this is the connection diagram:
3d touch 接法.png (398.84 KiB) Viewed 8570 times
you need to change the firmware and update.
You can refer to this:
http://www.geeetech.com/wiki/index.php/ ... ing_Sensor
Posted: Mon May 25, 2020 12:35 pm
by alexy34
Hi William
I took a look at marlin arduino, it's complicated, I'm going to drop the auto leveling because I don't want to have a problem with the firmware again.
Posted: Mon May 25, 2020 1:48 pm
Hi, according to the manual step by step operation is not complicated. 3Dtouch can automatically level, which is more convenient for future use.
Posted: Tue May 26, 2020 10:25 am
by alexy34
Hi William
I did the 4 steps according to the manual, but when I checked the coding it gave me an error.
You can see the pictures, I did the same thing as the manual.
Where is the problem ?
Posted: Tue May 26, 2020 3:49 pm
Sorry, I just confirmed that there is no need to change the firmware, this firmware supports 3dtouch, you can just connect the auto-leveling sensor and do the setup on the LCD screen.
Posted: Thu May 28, 2020 2:14 pm
by alexy34
Hi William
Are you sure i don't need to change or upgrade firmware ?
Just I need to connect the auto-leveling sensor and do the setup on the LCD screen ?
Posted: Thu May 28, 2020 4:34 pm
yes.
Posted: Thu May 28, 2020 4:37 pm
by alexy34
Thank you
Posted: Thu May 28, 2020 4:59 pm
you are welcome!
