Auto bed leveling on A30 connection.
Hi everyone,
I want to install a 3DTouch auto bed leveling sensor on my A30.
Did these pins on the back of extruder are for connection ? P.S. see picture.
Anyone has a picture how these plugs are connected ?
Do i need a firmware update ? or just connect the auto leveling sensor and do the setup on the lcd screen ?
- Auto leveling sensor pins ?
- auto leveling.PNG (1.42 MiB) Viewed 8571 times
Re: Auto bed leveling on A30 connection.
Hi,this is the connection diagram:
You can refer to this:
http://www.geeetech.com/wiki/index.php/ ... ing_Sensor
you need to change the firmware and update. You can refer to this:
Hi William
I took a look at marlin arduino, it's complicated, I'm going to drop the auto leveling because I don't want to have a problem with the firmware again.
Hi, according to the manual step by step operation is not complicated. 3Dtouch can automatically level, which is more convenient for future use.
Hi William
I did the 4 steps according to the manual, but when I checked the coding it gave me an error.
You can see the pictures, I did the same thing as the manual.
Where is the problem ?
- step 1
- step 1.PNG (27.4 KiB) Viewed 8550 times
- step 2
- step 2.PNG (44.8 KiB) Viewed 8550 times
- step 3
- step 3.PNG (27.3 KiB) Viewed 8550 times
- step 4
- step 4.PNG (30.05 KiB) Viewed 8550 times
- coding error
- coding error.PNG (122 KiB) Viewed 8550 times
Sorry, I just confirmed that there is no need to change the firmware, this firmware supports 3dtouch, you can just connect the auto-leveling sensor and do the setup on the LCD screen.
Hi William
Are you sure i don't need to change or upgrade firmware ?
Just I need to connect the auto-leveling sensor and do the setup on the LCD screen ?
yes.
Thank you
you are welcome!
