Auto bed leveling on A30 connection.
alexy34
Post by alexy34 »
Hi everyone,
I want to install a 3DTouch auto bed leveling sensor on my A30.
Did these pins on the back of extruder are for connection ? P.S. see picture.
Anyone has a picture how these plugs are connected ?
Do i need a firmware update ? or just connect the auto leveling sensor and do the setup on the lcd screen ?
Auto leveling sensor pins ?
auto leveling.PNG (1.42 MiB) Viewed 8574 times
Re: Auto bed leveling on A30 connection.
Hi,this is the connection diagram:
3d touch 接法.png (398.84 KiB) Viewed 8571 times
you need to change the firmware and update.
You can refer to this:
http://www.geeetech.com/wiki/index.php/ ... ing_Sensor
alexy34
Post by alexy34 »
Hi William
I took a look at marlin arduino, it's complicated, I'm going to drop the auto leveling because I don't want to have a problem with the firmware again.
Hi, according to the manual step by step operation is not complicated. 3Dtouch can automatically level, which is more convenient for future use.
alexy34
Post by alexy34 »
Hi William
I did the 4 steps according to the manual, but when I checked the coding it gave me an error.
You can see the pictures, I did the same thing as the manual.
Where is the problem ?
step 1
step 1
step 1.PNG (27.4 KiB) Viewed 8553 times
step 2
step 2
step 2.PNG (44.8 KiB) Viewed 8553 times
step 3
step 3
step 3.PNG (27.3 KiB) Viewed 8553 times
step 4
step 4
step 4.PNG (30.05 KiB) Viewed 8553 times
coding error
coding error
coding error.PNG (122 KiB) Viewed 8553 times
Sorry, I just confirmed that there is no need to change the firmware, this firmware supports 3dtouch, you can just connect the auto-leveling sensor and do the setup on the LCD screen.
alexy34
Post by alexy34 »
Hi William
Are you sure i don't need to change or upgrade firmware ?
Just I need to connect the auto-leveling sensor and do the setup on the LCD screen ?
yes.
alexy34
Post by alexy34 »
Thank you
you are welcome!
