A30T - 3DWifi - Upload GCODE
ewo68
Post by ewo68 »
I have a GEEETECH A30T.
Why can't we upload gcode to us on the SD card via wifibox?
I would have liked to use Octoprint if not, but I lose all the functions of recovery after electric cut or end of filament detection. And this because of Smartto which does not evolve.
Re: A30T - 3DWifi - Upload GCODE
Sorry, this feature is temporarily unavailable.
Langworthgh
Post by Langworthgh »
Save your money and don't buy this, i bought it thinking it would be nice to print wirelessly, and i got everything set up. First of all there is no support to use within windows which is the entire propose of going wireless to connect your computer. Secondly you have to use Android or ios which wouldn't be a problem IMO but you are forced to slice with crappy cloud creality slicer with no way to access the g code remotely . So another words even if you want to use your own g code sliced with cura you can't because even after you slice your stl to g code with crappy creality cloud slicer there is no way to replace crappy gcode with cura gcode because it's on a freaking cloud that you can't hack into and replace. So there is no way to print a cura gcode by hacking or any other means of replacing the g code because it's on a fucking cloud server that's unaccessible through any kind of file explorer or ftp server. So until someone comes up with a cura plugin to make this work out a way to hack replace the g code I'm stuck with a 20 dollar paper weight, thanks creality!!! Should have saved the 20 bucks and just got octoprint
Rapidfs Login
