Upgrading from A30M to A30T - No UI upgrading?
Posted: Sun Jun 21, 2020 12:47 pm
by AlexanderMason
I have successfully updated my A30M to an A30T(info shows A30T). Only the display UI files don't show the correct parts(mixing interface with 3 extruder) of an A30T.
I follow the step by step guide at the firmware on the side.omegle xender
-> Put the system and the A30T_S02_V1_01.bin to root card.
-> add a config.txt (with boot:1;bin_name:A30T_S02_V1_01.bin;) to root of sd card
-> start printer again
-> nothing happen
I checked the usb port on the side and directly on the mainboard.
What can I do? Any helps?
Re: Upgrading from A30M to A30T - No UI upgrading?
Posted: Mon Jun 22, 2020 2:33 pm
Hi, SD card should be put in
to this card slot.
