I got my very first 3D printer and wanted to test it by printing the benchy. So I added the printer in cura via custom fff printer, entered the dimensions, filament size, heated bed etc. After putting in filament and leveling the bed I started the print and the printer started, but the nozzle wasn't nearly where I leveled it, but rather 2-3 mm above the plate. Obviously i canceled the print.
Did anyone have the same problem or know where this may come from? Could false settings in cura be the cause or did I fail at leveling the bed correctly? Or is it something I totally missed?
I researched on the internet and I saw you can set an z offset value in your starting gcode. Should I just try to find a value to lower the nozzle?
Thanks for your help!
Problem with Geeetech A30: Z Axis is 2-3mm above the bed at the start of the print
owlietenil2
Re: Problem with Geeetech A30: Z Axis is 2-3mm above the bed at the start of the print
Gree technology is the technology that is assisted toward the technology related terms for making the technology implementation easier to them. The 3D printer has assisted the making of A 30 series at the link of https://www.toppaperwritingservice.com/ ... ssays-com/ with the topic of problems faced by the music sections.
