A10 with 3DTouch not responding to Z-offset??
AmirJustin
Post by AmirJustin »
I've got an A10 GT2650V3 with the official Geeetech Marlin 1.1.8 with 3D Touch enabled.
The probe works but it stops the Z-axis 2 mm above the bed, and I've got the probe set as high as the mounting bracket will allow.
Initially, I set the Z-offset and it worked. I ran the bed leveling and it worked until point 7 when the nozzle crashed into the bed. After that, the machine stopped responding to the probe and the nozzle kept crashing into the bed even when auto homing. I tried adjusting the offset and the machine acted like I changed nothing.
I rebooted the machine, reset it, etc and nothing fixed it. I decided to reflash the firmware and that got the probe working again but when I set a Z-offset, the machine still acts as if I did nothing.
I tried compiling the stock 1.1.8 firmware (no 3D Touch included) for myself, but when I flashed my version, the machine wouldn't home on Z-axis. Therefore, I don't think I can fix it in the firmware without creating other problems.
Can anyone out there give me some pointers?
mr_fosi
Re: A10 with 3DTouch not responding to Z-offset??
Post by mr_fosi »
I think the main pointer is that the 3DTouch is hot garbage.
I posted about my experience back in March: https://www.geeetech.com/forum/viewtopi ... 98&t=70251
And I've seen other threads since then and they all end the same way: with the user throwing the sensor in the trash or the parts bin.
Save yourself the headache and dump it.
