Hello!
2 months or so ago I purchased a geeetech a20m with a bltouch sensor and I built the printer and installed the sensor. After I got it all assembled correctly I couldn't get the printer to work. I correctly installed to sensor and correctly flashed the firmware of my printer to enable the sensor. When I started my first print the printing head would just jam into the buildplate and won't stop doing that so I guessed there would be something wrong with the offset, I tried to fix that and I got it to stop only going down and putting A LOT of pressure onto the head into the buildplate. but now if I start a print the printer tries to level itself with the sensor and just keeps going up and up and never reach the buildplate. I HAVE NOT GOT THIS PRINTER TO WORK IN OVER 2 MONTHS and I couldn't get a refund, what am I supposed to do? Could anyone please suggest a fix? Even if I remove the sensor could I downgrade again and get the correct offset? Or is there something else wrong with this machine?
Geeetech a20m problems
blackyman7
Jump to
- Firmware
- 3D Printer
- ↳ Thunder
- ↳ Mizar Pro
- ↳ Mizar S
- ↳ Mizar
- ↳ Geeetech I3 Pro B
- ↳ Geeetech I3 Pro W
- ↳ Geeetech I3 Pro X
- ↳ Geeetech I3 Aluminum
- ↳ Geeetech I3 Aluminum Pro
- ↳ Geeetech I3 Duplicator 5
- ↳ Geeetech I3 Pro C
- ↳ Geeetech I3 M201
- ↳ Geeetech A10 Series
- ↳ A10T
- ↳ Geeetech A20 Series
- ↳ Geeetech A20
- ↳ Geeetech A20M
- ↳ A20T
- ↳ Geeetech A30 Series
- ↳ A30M
- ↳ A30 PRO
- ↳ Geeetech E180 Mini
- ↳ Geeetech MeCreator2
- ↳ GiantArm D200
- ↳ Geeetech Delta Series
- ↳ Geeetech DP200 Series
- 3D Printing Software
- ↳ Software
- ↳ Wifi Box
- ↳ Bug report
- ↳ Download
- Hardware
- ↳ 3D Printer Hardware
- ↳ Stepper Motor
- ↳ Control Board
- ↳ Extruder
- ↳ Hot bed
- ↳ LCD Panel
- ↳ Power Supply Unit
- ↳ Assembly
- ↳ Others
- Print Quality
- Resoures Sharing
- Feedback&Suggestion
- Project Talent Show
- Other Discussion
- ↳ Leveling Guide
- ↳ Open Hardware
- ↳ Mods And Hacks
- ↳ Products FAQ
- ↳ Tips & Tricks
- ↳ Discuss & Help
- ↳ Windows
- ↳ MAC
