Request Config Files
McgLance
Post by McgLance »
Looking for any and all Config files you guys might have for the A30T, for any and all slicers..
I'd like to play with as many as I can, but dont have configs for them all..
Not to mention the downloads page has it for only for Cura, and a video setup for Repetier Host.. that uses the Cura Slicer.. but when I do that it always slicers from extruder 1 even tho I have extruder 3 selected for a single color print.
Annoying so far..
Also I do own a PrusaMk3s, and I like the initial process it does and the order it does it... the problem I have with the a30t is ooze while it's leveling, it does no purge line...
is there gcode I can add to allow for a purge line to remove the ooze as it can be very difficult to get to once printing is underway..
Thx for any help getting this printer up and running effectively.
lion
Re: Request Config Files
Post by lion »
Hi,You can refer to this video for the profile you mentioned.
https://www.youtube.com/watch?v=_limgP8 ... pL0zNWG7ne
In response to the ooze situation you mentioned, maybe you can let the A30T auto-leveling and then heat up, which may solve this situation.
