EasyPrint Config File for I3 Pro W
CarsonGrey
Post by CarsonGrey »
I have spent a lot of time trying to get 3D Benchy to print correctly in PLA. I have reduced bed temp to stop sagging. I have reduced speeds to stop benchy from lifting off of the bed. With my Benchy, you can see through the bottom from the egg-crate like matrix it was printed from.
I started with the custom high config Speed Test essay writer in EasyPrint and have been modifying it to get it to look good.
I was wondering is someone already has a "good" EasyPrint config file for PLA that I can try.
Top
Re: EasyPrint Config File for I3 Pro W
Hello, provide you with a few EasyPrint configuration pictures. :D You can also modify it yourself.
victorbradford
Post by victorbradford »
I always mess with these kind of issues because I am not good with printers as it takes time to resolve the issue
From cheap reliable essay writing service
robinjamess
Post by robinjamess »
CarsonGrey wrote: Thu Aug 20, 2020 12:44 am I have spent a lot of time trying to get 3D Benchy to print correctly in PLA. I have reduced bed temp to stop sagging. I have reduced speeds to stop benchy from lifting off of the bed. With my Benchy, you can see through the bottom from the egg-crate like matrix it was printed from.
I started with the custom high config in EasyPrint and have been modifying it to get it to look good.
TcsWebmail DadeSchools Upsers
Top
I began using it to force myself to learn the command line of Linux. I quickly realized it did more: it kept the distraction away that desktops gave me. In other words, it calmed me down.
This coincided with me moving away from Windows all together and deciding to use Linux instead.
To add to this with some dramatic flair. I have a history of depressions (the serious kind) and find it difficult to focus on anything, this is where i3 came to the rescue. It helped me focussing on the words.
