Help with new A30T
Posted: Thu Aug 27, 2020 10:58 pm
by jflaws
Assembly of unit was no problem, but went to level the bed. when I select manual control nothing will happen. If I hit "Home" the Y stage moves until it hits the limit switch in the back then it will not do any moves. No Manual control in any direction, checked the limit switch it seems to work ok, not sure what to do from here, is there a support # or can someone call me? 865-384-1943
Re: Help with new A30T
Posted: Fri Aug 28, 2020 1:49 pm
1. You can check whether the y-axis stopper is properly connected.
2. You can test whether the endstop works normally.
http://geeetech.com/forum/viewtopic.php?f=17&t=60927
3. You can exchange the drive of the y-axis and other axes to see if it is a drive problem.
Posted: Sat Sep 05, 2020 1:39 am
by 3dprintr
My prints have been coming out weird, some prints come out unfinished, and there is major stringing happening.
Posted: Sat Sep 19, 2020 6:50 pm
by martyray
that's interesting .
im getting a few unfinished prints as well.
single colour no problems.
multi colour finishes before pint in complete
Posted: Wed Sep 23, 2020 3:56 pm
by KriKri854
Hello, I've also trouble with multicolour.
I've read a long while ago someboday had made a online tool to modify colors in gcode but I can't find it anymore. Anybody?
Thx.
The mixing tool from geeetech shuts down each time.
Posted: Sat Sep 26, 2020 3:27 pm
by annaph
William wrote: Fri Aug 28, 2020 1:49 pm
Thankyou so much this was very helful
Posted: Tue Nov 10, 2020 9:21 pm
by NoahGreat
