A30M Extruding different lengths between sides for same feed length
Deadeye
Post by Deadeye »
Hi, I have an A30M and I’m trying to calibrate the Filament steps. I have it set to 140 and when I try to extrude 100mm, on E0 it extrudes 90mm and on E1 it extruders 100mm. Any ideas why there is a difference?
Re: A30M Extruding different lengths between sides for same feed length
Hello, the tightness of your extruder gear may be the cause of this phenomenon, you can calibrate the extruder, you can refer to the link below for calibration. :D
https://www.youtube.com/watch?v=xzQjtWhg9VE
