A30 Extruder Caliberation!!
Re: A30 Extruder Caliberation!!
Hello, if you can't use the LCD screen to control, you can connect the computer with a USB cable, and use the slicing software, such as repeter-host, to extrude 100mm.
I used the PC software Repetier-Host. Connect to printer via USB, then dispense 100mm on manual control.
