So, this is my first print, and I have no idea why this happened.
Can someone tell me what needs adjusting and why it happened.?
https://ibb.co/N36yd8C
Also after cooling off, the model will not come off the table.
Need help 1st time print
Re: Need help 1st time print
Hello, are you M series or T series printer? Whether the other extruder also put consumables, this is the test file printed by the dual extruder, you may not put consumables.
Regards.
Regards.
Thanks for the reply.
This is A10M
I used one roll of filament, on E1.
The issue is I printed again and the same problem. The top of the DOG is garbage.
This is A10M
I had the same issue.
