I wanted to check my extruder. I connected the printer via usb. I am using repetier 2.1.6. I made a mark at 100 and 120mm on the filament. In manual control, I sent the M83 command to switch the extruder to relative mode. Then sent the command G1 E100 F100, I had to send it four times before it was accepted (normal?). Then I measured the filament, for 100mm I only used 93mm. In the tutorial I am using, I am told to send the M503 command, that a value string will appear on the screen and to look for the line echo: M92, then to find the value E. The problem, is that nothing is displayed on the screen, therefore impossible to find this value, in order to modify it. What is the solution? Thank you in advance.
A30T Extruder Calibration
michaeldaivd62
buy tiktok likes uk
Therefore, take a little time to read through the website carefully to find out more about what is available before buying your likes or for that matter to find out about the history of your favorite cartoon character or to create your very own page and then see what the likes are for that particular cartoon character that you are thinking about buying. The bottom line is that it is always good to spend a little time before buying any likes because you will end up spending much time and money if you buy TikTok likes that are buy tiktok likes uk
Re: A30T Extruder Calibration
I managed to do this with smartto motor tool.
KeepCool83
Hi, i have exactly the same issue like you before.
Can you please tell me, how you did it?
With Smartto Motor Tool 1.2 i only see one extruder.
Thanks in advance for your help!
nickscorpion
Also squeezed out 93mm. I changed the settings, but the problem is that the first extruder extrudes 105mm, and the second and third as expected 100mm. Now I'm thinking how to change the settings only for the first one. Or you will have to set the flow for the first extruder less. Or does the support team have anything to suggest?
