Hey Guys,
i have make a stupid mistake..
My Geeetech A30T has problems with leveling. After every print, i have to level again and again.. During the printing process, he just begins to stop moving up the Z axis properly.
So i try to upgrade the firmware.. I had not seen that version 1.02.03 was installed and I installed version 1.02.02. Now the printer is no longer working properly. I've been looking for V1.02.03 for hours, but just can't find it. Can someone help me?
thanks in advance
best regards
Kevin
A30T - Look for Firmware V1.02.03
Prattville
Re: A30T - Look for Firmware V1.02.03
A30 firmware. In any case, when I attempt to transfer the "M" document, it says it is updating and says At the point when I look here just observe up to You select the A30 and the most recent firmware V1.38.59.
TellPopeyes Customer Feedback
You mean i should try the A30 Firmware? I cant believe that this worked because the A30T Firmware is definitely different from the A30 Firmware...Prattville wrote: Sat Dec 26, 2020 3:36 pm A30 firmware. In any case, when I attempt to transfer the "M" document, it says it is updating and says At the point when I look here just observe up to You select the A30 and the most recent firmware V1.38.59.
Or what would you like to say?
best regards
Hi Kevin
I have the same Problem here. Did you find a solution in the meantime?
Thank you for your answer
Stefan
Stefan
Nownlater82
Okay so after hour of research and a brilliant husband we found a solution that works.
Video Guide
https://www.bing.com/videos/search?q=ge ... &FORM=VIRE
Update firmware (Geeetech A30Pro, A30M, A30T 3D printer) - Bing video
Watch the video first, then start the process. These files are for the A30T printer made by Geeetech.
Here is the website to which you can download the files from. Make sure you select the correct type of computer
That you are using, ie: mac, ios, windows.
https://www.geeetech.com/download.html?download_id=40
Hope this helps
Video Guide
Hope this helps
- 20210109_130044.jpg (277.72 KiB) Viewed 6976 times
