Nozzle drags through model ?.
alexsunny123
Post by alexsunny123 »
I'm new to the forum - just built the i3 Pro W; had all the usual teething problems and got through to my first print of a Benchy which went fine. However I haven't been able to get another successful print out because the nozzle starts to drag into the model after a few layers of printing - this then triggers a Mintemp warning while the head remains hot. I have very carefully leveled the bed before the failed prints and I have moved the z axis by 0.1 increments through the trouble area with no problems. It looks to me like the nozzle needs more clearance but I don't know if that's right and I can't find out how to adjust the clearance.
thanks
alexsunny
jonsag
Re: Nozzle drags through model ?.
Post by jonsag »
Sounds like the Z-stepping is off somehow.
Strange that you got a successful bency, however...
Double check that 1mm increment in Z really is 1mm.
Also check extrusion for over extrusion.
/jon
