Replacement filament feed?
hof
Post by hof »
My E180 filament feed is cracked and so the gear wheel isn't gripping the filament enough to feed it.
I have used epoxy resin to repair it but the force required to grip the filament means it just keeps breaking.
Can I buy a replacement feed for this printer? I only need the plastic arm that holds the smooth wheel to be honest.
Admin
Re: Replacement filament feed?
Post by Admin »
Hello, you can contact the sales team of geeetech:
sales@geeetech.com
They will provide you with a quote.
charlottejenkins8
Post by charlottejenkins8 »
Changing filament improperly might done permanent damage to your 3D printer. Step 1: Load the replacement spool on the filament slot.
Target Card Balance Now
