Never been able to print
tkw9700
Post by tkw9700 »
My husband bought me this printer a year or so ago and I have yet to get a single print from it. After adjusting and fine tuning the setting I got nothing. Now the x axis seems to get stuck and will not move correctly at all. Any suggestions??
Admin
Re: Never been able to print
Post by Admin »
Hello, about printing, you can try to print some test files, such as this Cube, to see the effect, you can search for many related videos processed by slicing software on YouTube.
Regarding the problem of the X-axis stuck, please check whether the X-axis limit switch connection line is properly connected, and whether the limit switch can work normally by manually controlling the X-axis to ensure that the limit switch will not be turned on all the time.
You can also check the drive on the motherboard, exchange the drive of the X axis and the Y axis to see if the fault is exchanged, and eliminate the influence of the drive.
If you still have any questions, please contact geeetech official through ticket.
ticket process.rar
(389.76 KiB) Downloaded 350 times
cube.rar
(116.75 KiB) Downloaded 356 times
