Not moving on X or Y axis
Jon30b
Post by Jon30b »
The extruder wont' move on the X or Y axis. I have updated the firmware and I know the X axis rods are level because I have adusted them using a spirit level?
Admin
Re: Not moving on X or Y axis
Post by Admin »
Hello, you can check whether the limit switch can work normally, it may be that the limit switch is stuck, please reconnect it.
In addition, you can also directly exchange the x-axis and Z-axis motor connection lines on the main board. This method can be used to test whether the motor problem is the main board or the drive problem.
