Since i updated Cura to 4.8.0, it seems the purge line disapperead.
I tried some code but no one was good.
Can someone share a simple startup purge line Gcode to add to Cura for my A20M ? This would help some filament stick better on first layer. Now i have to manually remove the few millimeters of filament down the nozzle just before print starts.
Best regards.
Help with purge line Gcode
Re: Help with purge line Gcode
Up.
No one can help ?
No one can help ?
Hello, the simplest way, you can directly select the skirt in the slicing process, which can also achieve the same effect.
Or you can add the following gcode
G1 X180 E60 F300
G1 X180 E60 F300
