Geeetech a30 Not extruding filament
LavenderBirch
Post by LavenderBirch »
Feeder is Not pushing the filament
Hi guys. I have a little problem with my 3d printer. When i‘m loading or unloading new fillament the printer pushes it fine through the tube. But when i start a print the filament doesn‘t move anymore. The Motor with the gear is rotating but the feeder wheel is standing still. Any suggestions? Ps the Printer is a Geeetech A30Tweakbox Appvalley https://vlc.onl
Admin
Re: Geeetech a30 Not extruding filament
Post by Admin »
Hello, it may be that the feeding kit is too loose. You can adjust the pressure of the lower spring so that it can engage the filament exactly.
violasim
Post by violasim »
Nope, same filament, same Cura settings, same ambient conditions and the filament WILL NOT adhere to the bed now! It just curls around the extruder nozzle.
Myloweslife
Admin
Post by Admin »
Hello, maybe the hot bed is not leveled correctly?
You can slow down or change the printing area to see if the consumables stick to the hot bed.
