Z Axis out of synch
Ilhom
Z Axis out of synch
Post by Ilhom »
I am having problems with my new Geeetech Prusa I3 Pro W. The right side of the Z axis is slightly higher than the left side and if I try to fix it manually and then move the axis with the motor the left side gets stuck until it's out of synch again. Then it works normal (except for the fact that the sides are not straight).
I also recorded two videos, here they can be downloaded:
https://www.mediafire.com/file/a1fnhfgx ... p.zip/file
Admin
Re: Z Axis out of synch
Post by Admin »
Hello, you can refer to the solutions in the forum to see if it works:
http://geeetech.com/forum/viewtopic.php?f=82&t=60931
http://www.geeetech.com/forum/viewtopic ... 917(thanks
Ilhom
Post by Ilhom »
Apparently it's fixed. Right now it is up and running. The stepper motor driver didn't get enough voltage and now both are synched, even after going up and down several times.
